Easy way/Best pratices to identify Obsolute/Retired/Deleted in NXOpen method/Ufunc on NX migration
Builder
Builder
    Any easy way/Best pratices to identify NXOpen/Ufunc method that gets obsolute/Retired/Deleted during NX migrations. Currently we are able to get to know from Release notes & manually checking the list against to Visual studio/Eclipse NX projects. I'm thinking to have some option or macro which list all obsolute/retired/functions with in NXOpen/Ufunc project. Similar like where used in VS project/ Eclipse project.
ECR
PradeepECR
NX7.5 TC8/ NX9.0.2.5 TC10.2
Re: Easy way/Best pratices to identify Obsolute/Retired/Deleted in NXOpen method/Ufunc on NX migrati
This doesn't actually 'find' deprecated methods etc, but when using Java/Eclipse deprecated stuff gets highlighted when the code is recompiled:
Not sure if you get something similar in VS..
Production: NX8.5.3.3 MP11 64bit Testing: NX9.0.2.5
Builder
Builder
Yes, as you mentioned we will get in Eclipse for deprecated methods. Is it possible to show it as a error instead of warning by modify eclipse java settings.?
As I'm using VS2012, I don't see such methods shown as warning or error in IDE or during compile. I'm not sure any Visual Studio settings need to be checked for enable it.
PradeepECR
Yes, you can change Eclipse to issue errors for deprecated items instead of warnings by going to:
Window->Preferences -> Java -> Compiler -> Errors/Warnings -> Deprecated and restricted API
No idea about VS though. I don't use that other than to edit some legacy C code now and again.
Builder
Builder
Thanks for your solution on Eclipse/Java IDE.
PradeepECR
Honored Contributor
Honored Contributor
I'm using VS 2010 and when I try to use an obsolete or deprecated function it will show up in the "error list" as a warning. I keep the error list open and docked to the bottom of the window for quick reference while I work. I'd imagine VS 2012 has a similar option.
Builder
Builder
Yes cowski1 I'm also see it. Is it possible show it as error instead of warning.
PradeepECR
Honored Contributor
Honored Contributor
If you double click the "my project" icon and choose the "compile" tab, there is an option to "treat all warnings as errors". Locations listed are for VS 2010, they may be different in VS 2012.
Builder
Builder
Thanks for your solution. Is there any option to specially to treat deprecated method/class as error.
PradeepECR
