Editing an existing journal
DaveK 1st Gear
1st Gear
I keep saying this, and I need to actually find some time to learn...  this sample journal was provided by GTAC, to break wave links, but it only works on bodies.  I'd like to make it work on any wave linked geometry.  I see the line with "Linked body", would additional lines, or a different line do it?
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Imports NXOpen.Utilities
Module break_all_wave_linked_bodies
    Dim ufs As UFSession = UFSession.GetUFSession()
    Dim lw As ListingWindow = theSession.ListingWindow
    Sub Main()
        Dim dispPart As Part = theSession.Parts.Display
        Dim thisFeat As NXObject
        Dim is_broken As Boolean
        Dim myFeats As Features.FeatureCollection = dispPart.Features
        Dim featureName As String
        lw.Open()
        For Each thisFeat In myFeats
            ufs.Modl.AskFeatSysname(thisFeat.Tag, featureName)
            lw.WriteLine("Feature: " & featureName)
            If featureName.Compare(featureName, 0, "Linked Body", 0, 11, True) = 0 Then
                lw.WriteLine("Breaking link...")
                ufs.Wave.SetLinkData(thisFeat.Tag, NXOpen.Tag.Null, NXOpen.Tag.Null, False)
                ufs.Modl.Update()
                ufs.Wave.IsLinkBroken(thisFeat.Tag, is_broken)
                lw.WriteLine("is_broken??? " & is_broken.ToString)
            End If
            ufs.Modl.Update()
        Next
    End Sub
  Public Function GetUnloadOption(ByVal dummy As String) As Integer
      Return Session.LibraryUnloadOption.Immediately
  End Function
End Module
-Dave
NX 11 | Teamcenter 11 | Windows 8.1
Re: Editing an existing journal
It looks like the program works for any feature, and is only checking the feature name to identify wave links. It looks like the program is checking if the first 11 characters of the feature name matches "Linked Body". If you want every feature whose name starts with "Linked", check the first 6 characters for that instead.
becomes
            If featureName.Compare(featureName, 0, "Linked", 0, 6, True) = 0 Then
I am not a real vb programmer, so test this first ;*)
Reference: https://msdn.microsoft.com/en-us/library/1e058ek8(v=vs.110).aspx
Mark Rief
Retired Siemens
DaveK 1st Gear
1st Gear
I'll give it a try, thanks.
-Dave
cowski1 3rd Gear
3rd Gear
GTAC has a sample that will check to see if a feature is linked to another part (nx_api5410). You should be able to use this in conjunction with the .SetLinkData method to break any wave link in the file. Also, see nx_api5409 for a fully functioning journal that makes use of the subroutine.
cowski1 3rd Gear
3rd Gear
Here's a quick journal based on my last post. The code has not been thoroughly tested...
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Dim theUfSession As UFSession = UFSession.GetUFSession()
    Dim theUI As UI = UI.GetUI()
    Sub Main()
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "break all wave links")
        lw.Open()
        Dim is_broken As Boolean = False
        For Each thisFeat As Features.Feature In theSession.Parts.Display.Features
            lw.WriteLine("Feature: " & thisFeat.GetFeatureName)
            If IsLinkedFeature(thisFeat) Then
                lw.WriteLine(" Breaking link...")
                theUfSession.Wave.SetLinkData(thisFeat.Tag, NXOpen.Tag.Null, NXOpen.Tag.Null, False)
                theUfSession.Modl.Update()
                theUfSession.Wave.IsLinkBroken(thisFeat.Tag, is_broken)
                lw.WriteLine(" is_broken? " & is_broken.ToString)
            End If
        Next
        lw.Close()
    End Sub
    Function IsLinkedFeature(theFeature As Features.Feature) As Boolean
        ' There is no NXOpen method available which can be used to determine if a feature
        ' is linked to another part, so this function demonstrates calling a Check-mate
        ' function to get that information.  See ER 6669518.
        Dim arule As String = "mqc_isLinkedFeature(" & theFeature.Tag.ToString & ")"
        Dim ruleName As String = ""
        theUfSession.Cfi.GetUniqueFilename(ruleName)
        theSession.Parts.Work.RuleManager.CreateDynamicRule("root:", ruleName, "Boolean", arule, "")
        Dim isLinked As String
        isLinked = theSession.Parts.Work.RuleManager.EvaluateAsString("root:" & ruleName & ":")
        theSession.Parts.Work.RuleManager.DeleteDynamicRule("root:", ruleName)
        If isLinked.CompareTo("TRUE") = 0 Then Return True Else Return False
    End Function
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
DaveK 1st Gear
1st Gear
@cowski1  I created a test file with a linked face, body, mirror body, curve, and a point.  Your journal broke the link on the face, and body.
-Dave
DaveK 1st Gear
1st Gear
Using my blunt force an ignorance approach, I have started to edit the original journal.  So far I have it breaking the linked face, body, datum, and curve.  I have not found the right terms for the linked point, and mirror body.
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
    Sub Main()
        lw.Open()
                ufs.Modl.Update()
			End If
			If featureName.Compare(featureName, 0, "Linked Face", 0, 11, True) = 0 Then
                ufs.Modl.Update()
            End If
			If featureName.Compare(featureName, 0, "Linked Composite Curve", 0, 11, True) = 0 Then
                ufs.Modl.Update()
            End If
			If featureName.Compare(featureName, 0, "Linked Datum", 0, 11, True) = 0 Then
                ufs.Modl.Update()
            End If
            ufs.Modl.Update()
        Next
    End Sub
  End Function
End Module
-Dave
cowski1 3rd Gear
3rd Gear
Ok then, try this one:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Sub Main()
        lw.Open()
                If TypeOf (thisFeat) Is Features.MirrorBody Then
                    'handle linked mirror body
                    'lw.WriteLine("linked mirror body found")
                    Dim mirrorBodyBuilder1 As Features.MirrorBodyBuilder
                    mirrorBodyBuilder1 = theSession.Parts.Work.Features.CreateMirrorBodyBuilder(thisFeat)
                    mirrorBodyBuilder1.Associative = False
                    Dim nullTaggedObject As TaggedObject = Nothing
                    mirrorBodyBuilder1.SourcePartOccurrence = nullTaggedObject
                    Dim nXObject1 As NXObject
                    nXObject1 = mirrorBodyBuilder1.Commit()
                    mirrorBodyBuilder1.Destroy()
                ElseIf TypeOf (thisFeat) Is Features.WavePoint Then
                    'handle linked point
                    Dim wavePointBuilder1 As Features.WavePointBuilder
                    wavePointBuilder1 = theSession.Parts.Work.Features.CreateWavePointBuilder(thisFeat)
                    wavePointBuilder1.Associative = False
                    wavePointBuilder1.SourcePartOccurrence = nullTaggedObject
                    nXObject1 = wavePointBuilder1.Commit()
                    wavePointBuilder1.Destroy()
                ElseIf TypeOf (thisFeat) Is Features.ExtractFace Then
                    'handle linked region
                    Dim extractFaceBuilder1 As Features.ExtractFaceBuilder
                    extractFaceBuilder1 = theSession.Parts.Work.Features.CreateExtractFaceBuilder(thisFeat)
                    extractFaceBuilder1.Associative = False
                    nXObject1 = extractFaceBuilder1.Commit()
                    extractFaceBuilder1.Destroy()
                Else
                    'handle the other linked stuff
                End If
            End If
            Dim nErrs1 As Integer
            nErrs1 = theSession.UpdateManager.DoUpdate(markId1)
            theSession.Preferences.Modeling.UpdatePending = False
        Next
        lw.Close()
    End Sub
    End Function
    End Function
End Module
DaveK 1st Gear
1st Gear
That broke everything!  cool, thanks.
-Dave
cowski1 3rd Gear
3rd Gear
Wow, this is the first time I've been thanked for breaking everything!
