cancel
Error code stability
I'm working on an application in which I need to distinguish between a couple of different NXExceptions thrown by the same NXOpen call for different reasons. The different exceptions contain different error codes; are these codes stable between NX versions?
Thanks!
Re: Error code stability
Hi TimW
Normally it remains same.
But better way would be you collect the string of the exception, it will be different in each case.So it is easily distinguishable.
Abhi
