Error macro because Windows and NX versions?
Hi all,
I have tested this journal on NX8.5  and Windows 7 and it works perfect.
But on NX9.0.2 and Windows 8.1 dosen't work, error on line 65. Why this error? How can be solved?
Re: Error macro because Windows and NX versions?
at least you should post what error message appears...
The error is because Windows 8.1
When I launch the journal the error is: Line 65: "Forms" isn't a "Windows" member.
I am not sure which update or configuration, I have make on Windows 8.1 or NX9.
try "system.windows.forms.dialogresult.OK" instead of "windows.forms.dialogresult.OK"
