Error when Exporting to IGES
I am trying to write a journal to export assembly file to IGES. As I only want to export the models in the parent, ignoring the ones in the children parts, I exported the selected objects in the parent. In my journal, I obtain the solid bodies, curves, and notes first, then export them. When I ran my journal, a window as following often pops up:
This doesn't happen on simple assembly files. Does anyone have any ideas?
Kai
Re: Error when Exporting to IGES
Can you post your code and a sample file where this happens?
