Error when launching a new process from NXMenu to connect to TCE
I have a specifc case where in i have to launch a new process from NX internal application;
for example: I am launching a new application(Process) from internal NX application which will connect to TCE and export some parts there;
When i try to do this i am getting the NX exception as "UF_INITILIAZE MAY NOT BE CALLED ONCE UF_TERMINATE IS CALLED"
is there any function or setting i need to do before i call initiliase to connect to TCE?
Any Help!
Thanks FL
