Export Order of Assembly VBA
Hello, I have put together some VBA to try and run measure bodies on the assembly that has been loaded in my Assembly Navigator. Currently the journal runs measure bodies on every part in the assembly, and then for every part it writes the volume, centers and extents to a spreadsheet. Now the journal works, however I can't figure out how to get it to run measure bodies on the assembly that has been loaded in the same order that the parts are in the navigator. Also, it would help if I could get it to also give me the descriptions provided for each part in the "Name" column in the navigator.
 I am using NX 9.0.3.4
Does anybody know how I can do this?
Re: Export Order of Assembly VBA
Honored Contributor
Honored Contributor
When you say the "Name" column, do you mean the "Desciptive part name", "part name", "component name", or some custom "name" column?
Also, are you running Teamcenter?
I am running Team center, and I mean the Descriptive Part Name to be exact.
