Export Parasolid or STEP
Hi
We currently have a routine that uses ug_inspect to look at a part file and export out a Parasolid form an NX file, the only drawback being that it takes out the largest solid by file size. 90% of the time this is fine, but there is theb odd occasion when the solid export is not correct.
Does anyone have a routine that can inspect an NX file and export out either a Parasoid or STEP of the Solid in view in the file, rather than inspect all solid (some of which may be hidden)?
Martyn, Snr CAE Engineer, Renishaw PLC
NX10 Tc10
Re: Export Parasolid or STEP
I'm using a macro to export all visible Solids and exiting NX after that.
This works fine for us.
Mit freundlichen Gr??en / With kind regards
i.A. Dipl.-Ing. (FH) Stefan Walder
CAD Management
stefan.walder@gira.de
Tel +49(0)2195-602-319, Fax +49(0)2195-91603-319
Gira Giersiepen GmbH & Co. KG, Elektro-Installations-Systeme
Industriegebiet Mermbach, Dahlienstra?e, 42477 Radevormwald, Deutschland
Intelligente Geb?udetechnik von Gira. www.gira.de
Handelsregister AG K?ln HRA 16352
Pers?nlich haftende Gesellschafterin: GAV Management GmbH,
Handelsregister AG K?ln HRB 50479
Gesch?ftsf?hrer: Dipl.-Kfm. Dirk Giersiepen,
Dipl.-Wirtschafts-Ing. (FH) Oliver Borchmann, Alfred A. Bulitz,
Dipl.-Kfm. Thomas Musial
Gira Giersiepen GmbH & Co. KG, Electrical installation systems
Industriegebiet Mermbach, Dahlienstra?e, 42477 Radevormwald, Germany
Intelligent building technology by Gira. www.gira.com
Register of Business Names: AG K?ln HRA 16352
Partner Personally Responsible: GAV Management GmbH,
Register of Business Names: AG K?ln HRB 50479
Managing Directors: Dipl.-Kfm. Dirk Giersiepen,
Mit freundlichen Grüßen / With kind regards
CAD Management
Industriegebiet Mermbach, Dahlienstraße, 42477 Radevormwald, Deutschland
Intelligente Gebäudetechnik von Gira. www.gira.de
Handelsregister AG Köln HRA 16352
Persönlich haftende Gesellschafterin: GAV Management GmbH,
Handelsregister AG Köln HRB 50479
Geschäftsführer: Dipl.-Kfm. Dirk Giersiepen, Alfred A. Bulitz,
Industriegebiet Mermbach, Dahlienstraße, 42477 Radevormwald, Germany
Register of Business Names: AG Köln HRA 16352
Register of Business Names: AG Köln HRB 50479
Hi
Probably should have said but this is done outside of NX using Poweshell, so I need something that works in a similar way.
NX10 Tc10
Esteemed Contributor
You can compile an EXE from NXOpen API that exports the requested formats.
Using "%UGII_ROOT_DIR%\run_journal.exe", you can also execute a recoded journal, that you edited to be more portable for the selection of the solid to export.
Both is done without the need to have an existing NX session running.
Production: NX10.0.3, VERICUT 8.1, FBM, MRL 3.1.4 | TcUA 10.1 MP7 Patch 0 (10.1.7.0) | TcVis 10.1
Development: VB.NET, Tcl/Tk Testing: NX12.0 Preparing: NX12.0
