Export STL with NX Open (c++)
Siemens Pioneer Siemens Pioneer
Siemens Pioneer
 I am trying to export an STL using NXOpen (c++). In journaling I can save the model as prt, but there is not option to record the action of exporting an STL in NXopen with c++. I only find the STL import option. Has anyone tried exporting STL with NXopen c++ before?
Thanks!
Re: Export STL with NX Open (c++)
GTAC has an example in C
http://solutions.industrysoftware.automation.siemens.com/view.php?si=nx_api1307
The solution center contains several examples in VB or C#, they might give hints as to what functions need to be called.
https://solutions.industrysoftware.automation.siemens.com/
Elaine,
It will not record in a Journal because it requires that you use functions from the Open C toolkit.  If you go to the solution center and search for:
sample program stl
you will find several examples.  After the initial search, filter by "nx_api" on the left, under document type, to limit the results to sample programs, and after that, you can filter by language extension if desired.
Best regards,
Steve
Siemens Pioneer
Thank you for your responses!
