Export to STEP214 failing in external mode
Hello All,
I am facing an issue whiling exporting solid bodies from a part to STEP214. Same code is working fine while debugging and internal mode.
Getting the attached error in external mode. Please let me know if any one have solution/work around for the same
Shivaji
Re: Export to STEP214 failing in external mode
Hello All,
Have you added %UGII_ROOT_DIR% to the %PATH% variable?
Best is to start your external application from a NX command prompt.
