Export version-specific parasolid
hello,
is there a way to export a version-specific parasolid file in VB .NET ?
Tnx
Re: Export version-specific parasolid
Yes.  You can use the wrapper method for UF_PS_export_linked_data.  In NXOpen  VB.Net you can find the wrapper in the docs under UFPs.ExportLinkedData, but you will need to look at the original function in the Open C Reference to see the details of the various parameters.
Honored Contributor
Honored Contributor
Yes, use the .ExportLinkedData method. Some example code can be found here:
http://nxjournaling.com/content/export-parasolid#comment-2825
excellent, thank you both
