External NXOpen API for Extracting Notes from Drawing file using C Language
Builder
Builder
I am looking for API in NXOPEN(C Language) to extract Notes from Drawing (Associated to Views and also not associated).
I found the same API in C#. Can anybody help me find the same in C Language, as i would be using the same with UGMANAGER in connected mode with TeamCenter.
Thanks..
Santosh
12 REPLIES 12
Re: External NXOpen API for Extracting Notes from Drawing file using C Language
What API function have you found?
If you are running in NX, you are not forced to use the old ANSI C language in managed mode.
Builder
Builder
I have found that the Parts namespace has the members to access NoteCollection and extract the text.
I am not sure what managed means, but i am not opening NX application. i.e., External program
Santosh
You mentioned UGmanager, which implies managed mode and not native Smiley Wink
You can build a .NET external application, which is the current preferred way of creating NXOpen executables.
Using the ancient NXOpen C API will force you to compile separate executables for 32-bit and 64-bit platforms.
.NET allows to compile executables independent from the platform.
Builder
Builder
Can you provide an example with UGManager.
Santosh
See Sample NX Open .NET Visual Basic program : open part in native or nxmanager batch mode for an example.
Builder
Builder
Hi Stefan,
Can you also please send me a link to compile and link these kind of programs.
I compile C programs using the steps mentioned in this link.
Thanks & Regards
Santosh
Santosh
Start with the NXOpen Programming Tools Help and go to NXOpen Programmers Guide => Creating NXOpen Automation => Compiling and Linking Overview => Compiling and Linking NX Open for .NET.
@cowski1 wrote:
The compile and link process for .NET programs can be found here:
https://docs.plm.automation.siemens.com/tdoc/nx/10/nx_api/#uid:index_nxopen_prog_guide:id1142151:com...
The direct link is nice, but navigating through the entire NXOpen Help would be better, so one knows where information is for the future.
