ExtractFace/LinkedBody Question
Innovator
Innovator
You have Component "Alpha"
Component "Beta" is an immediate child of "Alpha.
Is there any way to see if Beta has Wave Linked anything into Alpha?
Re: ExtractFace/LinkedBody Question
You would have to check Alpha to see if it references external geometry. Individual parts do not keep track of everything that is referencing them.
Innovator
Innovator
I was afraid of that.
Thank you.
Have you checked any of the available items in "'Menu => Information => Assembly" for wave or similar?
- Loop through all the feature in ALPHA. Select only the wave linked feature
- Get the body/faces of that Wave Linked feature.
- Get the source body/face for each body/face using UF_WAVE_map_link_geom_to_source
- Get the owning component with OwningComponent() function in NXObject and check if the component is B.
Elias.
