cancel
Fail to record tool path verify by journaling
Dear all,
   This is my first time to post on the forums. So glad to join this community.
   I have a question when I journal the tool path verify. It can be recorded but all of the settings in verify could not be recorded.
   The target for me is to analyze the IPW. Once I give a point with normal direction the analyze tool will return me the area is cut or not.
   Thank you for your help.
Re: Fail to record tool path verify by journaling
Hi Oscar_Lee,
Most welcome to the community.
While recording journal did you see a green point appears in the option you are going to select, some time it will be half or in some option it won't appear at all.
The options with green light are the only one who can be recorded in journal completely.
Hope the option you are trying does not come under that catagory.
Abhi
