Failed in SignDotNet.exe DLL signing error: Signature is not found
Hi all,
I am trying to signing the DLL. I am getting error as "Assembly has not been compiled with an NX resource bundle Signature is not valid"
I am using NX10.0, and SignDotNET.exe from "C:\Program Files\Siemens\NX10.0\UGII"
Please find attached Image "SignatureIsNotFound.JPG".
Can you please help me ?
Thanks in advance,
Dinesh
Re: Failed in SignDotNet.exe DLL signing error: Signature is not found
You need to include %UGII_BASE_DIR%\UGOPEN\NXSigningResource.res as an embedded resource in your project. This resource needs to be embedded into the .dll you are trying to sign.
Yes,
You need to include %UGII_BASE_DIR%\UGOPEN\NXSigningResource.res into your project and change the "Build Action" property to "Embedded Resource". Compile the application once again and Sign it. It should work.
Yes it helped me and resolved my issue .Thank you very much for your help.
