Feature.Copy(xform)
Innovator
Innovator
Does anyody know how this works in the SNAP API?
I keep getting "A feature cannot be moved, because its position is controlled by its parents.
Even if I am trying to Move or Copy a feature that doesn't have a parent or child features.
Any idea would be very helpful. Thank you.
Re: Feature.Copy(xform)
What kind of object are you trying to move or copy?
You can try calling the Feature.Orphan method, to make sure the object is disconnected from its parents.
Actually, even if the object does have parents, the Copy function should work.
If you post your code, I expect people will help you with it.
山田
yamada
