Feature Subtype & Operation type
Hey all,
I have a simple question,
I got a feature and I want to get its subtype, but I only found in the documentation a method that returns the type.
Is there an API that give me the subtype?
Also I would like to know how to get the operation type too (all I got is the name).
Thanks.
Re: Feature Subtype & Operation type
If this is what you mean by feature's subtype:
You can try:
(but I didn't tried it)
Dim featureSubtype As Integer
Dim feature As CAM.FBM.Feature
Dim featureSubtypeAttr As CAM.CAMAttribute
'assuming that you assigned a value to "feature":
featureSubtypeAttr = feature.GetAttribute("SUBTYPE")
featureSubtype = featureSubtypeAttr.GetIntegerValue
 To get operation's type you can use:
Dim oper As Operation = WorkPart.CAMSetup.CAMOperationCollection.FindObject(operName)
Dim typOper As String = oper.GetType.Name
Marek Pawlus, NCmatic
Production: NX 12.0.1
Development: C#, Tcl/Tk, CSE
Thank you.
But:
1) In feature sub type I mean this:
2016-08-01 07_23_26-Machining Knowledge Editor - [knowledge _C__Users_xozh4v_Desktop_Tal's Stuff_].png
2) No such method like GetType in Operation class.
I'm looking for an API to get the operation type. Like the line in the Operation information.
@TomLeon wrote:
Thank you.
But:
This is not a sub-type, it is a type, since there are no sub-types in the FBM feature classes.
The structure is only used to allow inheritance of attributes.
