Find the expression associated with a dimension
How do I get the expression that is associated with a sketch dimension? I can get a SketchConstraint array using getAllConstraintsOfType(...), and I can get all of the Expressions with getAllExpressions(), but I cant find a way to map the expressions to their associated dimensions.
Re: Find the expression associated with a dimension
Once you have a reference to a SketchDimensionalConstraint object, you can use its properties to get the .AssociatedDimension and .AssociatedExpression.
That worked!  The trick was to cast it as a SketchDimensionalConstraint, because as a SketchConstraint, I didn't have those options.  Thanks.
