Finding Similar faces of different solid bodies..
Hello All,
Suppose there are two exactly same solid bodies present in NX modeling. Those are having numbers of different sized faces.Is there any possibility to search get those similar faces of different solid bodies?
Attachment is an image of what I want.
Thank you...
Abhi
Re: Finding Similar faces of different solid bodies..
There is a journal here that looks for identical, overlapping faces of sheet bodies. It's not quite what you are looking for, but you might be able to adapt it to your needs.
