Finish Walls operation - reach to faces
(NX CAM - JAVA)
I have a "Finish Walls" operation.
How can I reach to the faces that the operation works on?
Tom.
Re: Finish Walls operation - reach to faces
Finish Walls is planar milling, so it is boundary based.
You may select faces to define a boundary, but it is still a boundary.
In the new boundary dialogs, if you analyse the boundaries, you may be able to get the defining geometry, but I'm not sure.
Mark Rief
Retired Siemens
