Do you mean
Reply
Folderbrowserdialog : SendKeys VB.Net
[ Edited ]
I have a problem with the selection , the dialog dialog does not scroll to selected folder .I believe that it is a known problem.
link : FolderBrowserDialog.html
A solution it's "sending keys" .I try to know if i can do the same thing with nx open .I tried but it did not work.
My code below :
 Dim FlBrowserDialog As FolderBrowserDialog = New System.Windows.Forms.FolderBrowserDialog
   With FlBrowserDialog
       .SelectedPath = "C:\application\NX11\MACH\auxiliary"
       .ShowNewFolderButton = True
   End With
   SendKeys.SendWait("{TAB}{TAB}{DOWN}{UP}")
  If FlBrowserDialog.ShowDialog = System.Windows.Forms.DialogResult.OK Then
       dir = FlBrowserDialog.SelectedPath
   Else
       Exit Sub
   End If
@mkn
