Get NXOpen Journal full path at runtime
If I run a .NET (VB or C#) Journal inside NX (Developer->Play->Journal), is there a way to retrieve in the journal code, at runtime, the full path of the journal, i.e., the full path of the .vb or .cs file that was selected ?
Thanks.
Re: Get NXOpen Journal full path at runtime
theSession = Session.GetSession()
theJournalName = theSession.ExecutingJournal()
Thanks Jim.
