Get Top Level Component list of drawing File
Hello Team,
I want to get all the top level components/solids present in drawing file. I have tried to get it using below code but it gives all components but I am interested in top level. If you see the attached image I want only 3 componets
1. TOYCAR_AXLE_ASSY
2. TOYCAR_WHEEL
3. LAYER_ORGANIZE_TEST_PART
but I get all componets i.e.
1. TOYCAR_AXLE_ASSY
2. TOYCAR_AXLE
3. RIGHT_WHEEL - (TOYCAR_WHEEL)
4. LEFT_WHEEL - (TOYCAR_WHEEL)
5. LAYER_ORGANIZE_TEST_PART
Please help me in getting top level componets present in drawing.
Output should be as Required Output image...
Rupali
Re: Get Top Level Component list of drawing File
Sample program on the Solution Center:
https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&dt=nx-api&q=%22report+a...
If my link doesn't work, search for nx_api3114.  The example is called "report all immediate component names whether open or not".
