Get displayed color
Hello everyone,
I currently have a program that changes line colors through DependentDisplay.ApplyWireframeEdit. however, when I run the program twice it must ignore the previous colored lines.
Every time I check the color of a line in DraftingCurve.color, only the original color is displayed.
Is there a way to identify the displayed color and not the original color?
Thank you very much.
1 REPLY 1
Re: Get displayed color
Siemens Legend Siemens Legend
Siemens Legend
The color of a DraftingCurve is defined by the Visible Lines setting of the member view or by a manual view dependent edit for that object and Information->Object reports the object color and the view dependent edits color.
You can get the VDE color with the C API function UF_VIEW_ask_vde_data
(or the UFView wrapper method like UFView.AskVdeData in NET).
