Get multiple leaders data and create new FCF using same
I've below code which copies everything from exisitng PMI FCF and create a new one at the same location.
I just now wants to handle the case where multiple leaders are to FCF. I could retrieve leader data but can't make it to apply to new one. Any help please.
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Dim theSession As Session = Nothing
    DIm theUfSession As UFSession = Nothing
    Sub Main()
        theSession = Session.GetSession()
        theUfSession = UFSession.GetUFSession()
        Dim workPart As Part = theSession.Parts.Work
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        ' to avoid the circular references
        Dim fcfs As Annotations.Fcf() = workPart.Annotations.Fcfs.ToArray
        For Each myFCF As NXOpen.Annotations.Fcf In workPart.Annotations.fcfs.ToArray
            Dim nullNXOpen_Annotations_Fcf As NXOpen.Annotations.Fcf = Nothing
            Dim pmiFeatureControlFrameBuilder1 As NXOpen.Annotations.PmiFeatureControlFrameBuilder = Nothing
            pmiFeatureControlFrameBuilder1 = workPart.Annotations.CreatePmiFeatureControlFrameBuilder(nullNXOpen_Annotations_Fcf)
            Dim pmiFeatureControlFrameBuilder2 As NXOpen.Annotations.PmiFeatureControlFrameBuilder = Nothing
            pmiFeatureControlFrameBuilder2 = workPart.Annotations.CreatePmiFeatureControlFrameBuilder(myFCF)
            pmiFeatureControlFrameBuilder1.Origin.Plane.PlaneMethod = NXOpen.Annotations.PlaneBuilder.PlaneMethodType.ModelView
            ''' https://docs.plm.automation.siemens.com/data_services/resources/nx/10/nx_api/en_US/custom/nxopen_python_ref/NXOpen.Annotations.OriginBuilder.html#NXOpen.Annotations.OriginBuilder
            pmiFeatureControlFrameBuilder1.Origin.Anchor = pmiFeatureControlFrameBuilder2.Origin.Anchor
            pmiFeatureControlFrameBuilder1.Origin.OriginPoint = pmiFeatureControlFrameBuilder2.Origin.OriginPoint
            pmiFeatureControlFrameBuilder1.InheritFrom(myFCF)
            ''' Get and apply leader data https://community.plm.automation.siemens.com/t5/NX-Programming-Customization-Forum/Recreate-PMI-FCF-to-recreate-new-one/m-p/600135#M17667
            Dim draftingFeatureControlFrameBuilder As NXOpen.Annotations.DraftingFeatureControlFrameBuilder = workPart.Annotations.CreateDraftingFeatureControlFrameBuilder(myFCF)
            Dim leaderBuilder As NXOpen.Annotations.LeaderBuilder = draftingFeatureControlFrameBuilder.Leader
            Dim leaderDataList As NXOpen.Annotations.LeaderDataList = leaderBuilder.Leaders
            Dim leaderDatas As NXOpen.Annotations.LeaderData() = leaderDataList.GetContents()
            DispLeaderData(leaderDatas)
            Dim data As Annotations.LeaderData() = pmiFeatureControlFrameBuilder2.Leader.Leaders.GetContents()
            Dim leaderData1 As NXOpen.Annotations.LeaderData = Nothing
            leaderData1 = workPart.Annotations.CreateLeaderData()
            leaderData1 = data(0)
            pmiFeatureControlFrameBuilder1.Leader.Leaders.Append(leaderData1)
            '''Code to handle case when FCF is created with more than 1 leader (and more associations) and apply
            Dim fcf As NXOpen.Annotations.Fcf = CType((myFCF), NXOpen.Annotations.Fcf)
            Dim associatedObject As NXOpen.Annotations.AssociatedObject = fcf.GetAssociatedObject()
            Dim nXObject As NXObject() = associatedObject.GetObjects()
            Dim added1 As Boolean = Nothing
                For j As Integer = 0 To nXObject.Length - 1
                   ' theSession.ListingWindow.WriteFullline("Associative Object Tag : " & nXObject(j).Tag)
                    added1 = pmiFeatureControlFrameBuilder1.AssociatedObjects.Nxobjects.Add(nXObject(j))
                Next
            draftingFeatureControlFrameBuilder.Destroy()
            ''' https://docs.plm.automation.siemens.com/data_services/resources/nx/10/nx_api/en_US/custom/nxopen_python_ref/NXOpen.Annotations.AssociatedObjectsBuilder.html?highlight=nxopen.annotations#NXOpen.Annotations.AssociatedObjectsBuilder.Nxobjects
            pmiFeatureControlFrameBuilder1.Commit()
            pmiFeatureControlFrameBuilder1.Destroy()
            pmiFeatureControlFrameBuilder2.Destroy()
        Next
        lw.Close()
    End Sub
''' https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&q=NXOpen.Annotations.LeaderBuilder&file_type=text&i=nx_api6055&k=0&o=0
    Sub DispLeaderData(ByVal leaderDatas As NXOpen.Annotations.LeaderData())
        If leaderDatas Is Nothing Then Return
        If leaderDatas.Length = 0 Then Return
            For Each leaderData As NXOpen.Annotations.LeaderData In leaderDatas
                Dim type, subType As Integer
                Dim displayableObject As DisplayableObject = Nothing
                Dim view As View = Nothing
                Dim point3d As Point3d
                leaderData.Leader.GetValue(displayableObject, view, point3d)
                If displayableObject IsNot Nothing Then
                    theUfSession.Obj.AskTypeAndSubtype(displayableObject.Tag, type, subType)
                    theSession.ListingWindow.WriteFullline("Leader Associated to Object Type : " & type & " SubType : " & subType)
                    theSession.ListingWindow.WriteFullline(vbTab & "Tag    : " & displayableObject.Tag.ToString())
                    theSession.ListingWindow.WriteFullline(vbTab & "Origin : X" & point3d.X.ToString() & " Y" + point3d.Y.ToString() & " Z" + point3d.Z.ToString())
                    If view IsNot Nothing Then theSession.ListingWindow.WriteFullline(vbTab & "View   : " & view.Name)
                End If
            Next
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image when the NX session terminates
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
    End Function
End Module
Samadhan
GTAC | NX Help: NX1102 | NX1202 | NX1847
Please mark post as an "Accepted Solution", if it answers your question/is more helpful!
3 REPLIES 3
Re: Get multiple leaders data and create new FCF using same
Hi @SamadhanGaikwad
I have updated the source below to support the multiple leader options and also the associated objects to the new FcF
    Sub Main()
        lw.Open()
            ''Dim draftingFeatureControlFrameBuilder As NXOpen.Annotations.DraftingFeatureControlFrameBuilder = workPart.Annotations.CreateDraftingFeatureControlFrameBuilder(myFCF)
            ''Dim leaderBuilder As NXOpen.Annotations.LeaderBuilder = draftingFeatureControlFrameBuilder.Leader
            ''Dim leaderDataList As NXOpen.Annotations.LeaderDataList = leaderBuilder.Leaders
            ''Dim leaderDatas As NXOpen.Annotations.LeaderData() = leaderDataList.GetContents()
            ''DispLeaderData(leaderDatas)
			' to get and assign the leader data in new fcf (newly added)
            Dim leaderdata As Annotations.LeaderData() = pmiFeatureControlFrameBuilder2.Leader.Leaders.GetContents()
			DispLeaderData(leaderdata)
            For Each data As Annotations.LeaderData In leaderdata
                leaderData1 = data
            Next
            ' to get and assign the associated objects in new fcf (newly added)
            Dim objs As NXObject() = pmiFeatureControlFrameBuilder2.AssociatedObjects.Nxobjects.GetArray()
            pmiFeatureControlFrameBuilder1.AssociatedObjects.Nxobjects.Add(objs)
			' commented
            'Dim data As Annotations.LeaderData() = pmiFeatureControlFrameBuilder2.Leader.Leaders.GetContents()
            'Dim leaderData1 As NXOpen.Annotations.LeaderData = Nothing
            'leaderData1 = workPart.Annotations.CreateLeaderData()
            'leaderData1 = data(0)
            'pmiFeatureControlFrameBuilder1.Leader.Leaders.Append(leaderData1)
			' commented
            ''Dim fcf As NXOpen.Annotations.Fcf = CType((myFCF), NXOpen.Annotations.Fcf)
            ''Dim associatedObject As NXOpen.Annotations.AssociatedObject = fcf.GetAssociatedObject()
            ''Dim nXObject As NXObject() = associatedObject.GetObjects()
            ''Dim added1 As Boolean = Nothing
                ''For j As Integer = 0 To nXObject.Length - 1
                    ''added1 = pmiFeatureControlFrameBuilder1.AssociatedObjects.Nxobjects.Add(nXObject(j))
                ''Next
			' commented
            ''draftingFeatureControlFrameBuilder.Destroy()
        Next
        lw.Close()
    End Sub
Replace the above main sub in the code you have posted. I have commented some of the lines not required.
Hi @Manikandan_R ,
Thank you! Now I got it how to get leader and associated objects. Below is the final running code.
Option Strict Off
Imports System
Imports NXOpen
Module Module1
    Sub Main()
        lw.Open()
                leaderData1 = data
            Next
        Next
        lw.Close()
    End Sub
    End Function
End Module
Samadhan
Hi @Manikandan_R ,
In above code, the plane method is hard coded so I tried passing information of plane method from existing FCF to new one but still some PMI FCFs are not created with correct orientation. Can we improve the code? Can we also make it work for User Defined Plane method?
Samadhan
