Get points from selected sketch
I am new to NX programing, a have some experience with CATIA Macros. I work with vb.
I want to create Coordinate Systems on points from selected sketch Sketch. I have problem with using selection, how to get points when i select sketch.
Dim point1 As NXOpen.Point = CType(workPart.Points.FindObject("ENTITY 2 8 1"), NXOpen.Point)
(in catia it was just change one number like
 For i = 1 to sketch.points.count
Dim point1 As NXOpen.Point = CType(workPart.Points.FindObject("ENTITY 2 i 1"), NXOpen.Point)
I know i must replace this with user sel, but dont know how to do it.
Thx a lot.
Option Strict Off
Imports System
Imports NXOpen
Function SelectAnObject(prompt As String, ByRef selObj As NXObject) As Selection.Response
Dim theUI As UI = UI.GetUI
Dim cursor As Point3d
Dim typeArray() As Selection.SelectionType = {Selection.SelectionType.All, Selection.SelectionType.Faces, Selection.SelectionType.Edges, Selection.SelectionType.Features}
Dim resp As Selection.Response = theUI.SelectionManager.SelectObject(prompt, "Selection", Selection.SelectionScope.AnyInAssembly, False, typeArray, selobj, cursor)
If resp = Selection.Response.ObjectSelected Or resp = Selection.Response.ObjectSelectedByName Then
Return Selection.Response.Ok
Else
Return Selection.Response.Cancel
End If
End Function
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As NXOpen.Session = NXOpen.Session.GetSession()
Dim workPart As NXOpen.Part = theSession.Parts.Work
Dim displayPart As NXOpen.Part = theSession.Parts.Display
Dim markId1 As NXOpen.Session.UndoMarkId
markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Start")
Dim nullNXOpen_Features_Feature As NXOpen.Features.Feature = Nothing
If Not workPart.Preferences.Modeling.GetHistoryMode Then
Throw (New Exception("Create or edit of a Feature was recorded in History Mode but playback is in History-Free Mode."))
End If
Dim datumCsysBuilder1 As NXOpen.Features.DatumCsysBuilder
datumCsysBuilder1 = workPart.Features.CreateDatumCsysBuilder(nullNXOpen_Features_Feature)
Dim unit1 As NXOpen.Unit = CType(workPart.UnitCollection.FindObject("MilliMeter"), NXOpen.Unit)
Dim unit2 As NXOpen.Unit = CType(workPart.UnitCollection.FindObject("Degrees"), NXOpen.Unit)
theSession.SetUndoMarkName(markId1, "Datum CSYS Dialog")
Dim nullNXOpen_Xform As NXOpen.Xform = Nothing
Dim point2 As NXOpen.Point
point2 = workPart.Points.CreatePoint(point1, nullNXOpen_Xform, NXOpen.SmartObject.UpdateOption.WithinModeling)
Dim nXObject1 As NXOpen.NXObject
Dim xform1 As NXOpen.Xform
xform1 = workPart.Xforms.CreateExtractXform(point1, NXOpen.SmartObject.UpdateOption.WithinModeling, False, nXObject1)
Dim point3 As NXOpen.Point = CType(nXObject1, NXOpen.Point)
Dim point4 As NXOpen.Point
point4 = workPart.Points.CreatePoint(point3, nullNXOpen_Xform, NXOpen.SmartObject.UpdateOption.WithinModeling)
point4.RemoveViewDependency()
Dim datumAxis1 As NXOpen.DatumAxis = CType(workPart.Datums.FindObject("DATUM_CSYS(3) X axis"), NXOpen.DatumAxis)
Dim direction1 As NXOpen.Direction
direction1 = workPart.Directions.CreateDirection(datumAxis1, NXOpen.Sense.Forward, NXOpen.SmartObject.UpdateOption.WithinModeling)
Dim datumAxis2 As NXOpen.DatumAxis = CType(workPart.Datums.FindObject("DATUM_CSYS(3) Y axis"), NXOpen.DatumAxis)
Dim direction2 As NXOpen.Direction
direction2 = workPart.Directions.CreateDirection(datumAxis2, NXOpen.Sense.Forward, NXOpen.SmartObject.UpdateOption.WithinModeling)
Dim xform2 As NXOpen.Xform
xform2 = workPart.Xforms.CreateXform(point4, direction1, direction2, NXOpen.SmartObject.UpdateOption.WithinModeling, 1.0)
Dim markId2 As NXOpen.Session.UndoMarkId
markId2 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "Datum CSYS")
Dim markId3 As NXOpen.Session.UndoMarkId
markId3 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "Datum CSYS")
Dim cartesianCoordinateSystem1 As NXOpen.CartesianCoordinateSystem
cartesianCoordinateSystem1 = workPart.CoordinateSystems.CreateCoordinateSystem(xform2, NXOpen.SmartObject.UpdateOption.WithinModeling)
theSession.SetUndoMarkName(markId1, "Datum CSYS")
datumCsysBuilder1.Csys = cartesianCoordinateSystem1
datumCsysBuilder1.DisplayScaleFactor = 1.25
Dim nXObject2 As NXOpen.NXObject
nXObject2 = datumCsysBuilder1.Commit()
datumCsysBuilder1.Destroy()
End Sub
End Module
This is code take with jurnal whic i changed.
Re: Get points from selected sketch
NXOpen.Sketch.GetAllGeometry() will return an array of NXOpen.NXObjects containing all of the curves and points in the sketch. Loop through the objects in this array and retain those that are points.
Honored Contributor
Honored Contributor
Here's a quick journal showing the usage of NXOpen.Sketch.GetAllGeometry() as mentioned by @JimB. It processes the first sketch it finds in the work part and writes point information to the information window.
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Dim theUfSession As UFSession = UFSession.GetUFSession()
    Dim theUI As UI = UI.GetUI()
    Dim lw As ListingWindow = theSession.ListingWindow
    Sub Main()
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "NXJ")
        lw.Open()
        Dim partSketches() As Sketch = theSession.Parts.Work.Sketches.ToArray
        'if there are no sketches, exit journal
        If partSketches.Length = 0 Then
            Return
        End If
        'process the first sketch
        Dim sketchObjects() As NXObject = partSketches(0).GetAllGeometry
        If sketchObjects.Length = 0 Then
            lw.WriteLine(partSketches(0).Name & " contains no geometry")
        End If
        Dim sketchPoints As New List(Of Point)
        For Each temp As NXObject In sketchObjects
            If TypeOf (temp) Is Point Then
                sketchPoints.Add(temp)
            End If
        Next
        lw.WriteLine(partSketches(0).Name & " contains " & sketchPoints.Count.ToString & " point objects")
        For Each temp As Point In sketchPoints
            lw.WriteLine(temp.Coordinates.ToString)
        Next
        lw.Close()
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
Thx both of u,i made first steep, i get coorinates of the points from the selected sketch, i ll continue.  Whic is the best way for multiselection.
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpenUI
Imports System.Windows.Forms
Imports NXOpen.UF
Module NXJournal
    Function SelectSketch() As Sketch
        Dim ui As UI = ui.GetUI
        Dim message As String = "Select Sketch"
        Dim title As String = "Selection"
        Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart
        Dim keepHighlighted As Boolean = False
        Dim includeFeatures As Boolean = True
        Dim selectionAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
        Dim selectionMask_array(0) As Selection.MaskTriple
        With selectionMask_array(0)
            .Type = UFConstants.UF_sketch_type
            .Subtype = 0
        End With
        Dim selectedObject As NXObject = Nothing
        ui.SelectionManager.SelectObject(message, title, scope, selectionAction, includeFeatures, keepHighlighted, selectionMask_array, selectedObject, cursor)
        Dim Sketch As Sketch = CType(selectedObject, Sketch)
        If Sketch Is Nothing Then
            Return Nothing
        End If
        Return Sketch
    End Function
    Sub Main(ByVal args() As String)
        Dim ufs As UFSession = UFSession.GetUFSession()
        '   Menu: Insert->Datum/Point->Datum CSYS...
        End If
        lw.Open()
        Dim Sketch1 As Sketch = SelectSketch()
        Dim sketchObjects() As NXObject = Sketch1.GetAllGeometry
            End If
        Next
        lw.WriteLine(sketchObjects(0).Name & " contains " & sketchPoints.Count.ToString & " point objects")
        Next
        lw.Close()
        Dim datumAxis1 As NXOpen.DatumAxis = CType(workPart.Datums.FindObject("DATUM_CSYS(4) X axis"), NXOpen.DatumAxis)
        Dim datumAxis2 As NXOpen.DatumAxis = CType(workPart.Datums.FindObject("DATUM_CSYS(4) Y axis"), NXOpen.DatumAxis)
    End Sub
End Module
It works now, thanx again, any suggestion are welcome.
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpenUI
Imports NXOpen.UF
Module NXJournal
    'Function For SKetch selection
        Dim message As String = "Sketch selection for creating AS ..."
        Dim title As String = "Sketch Selection"
            .Subtype = 0
        End With
            Return Nothing
        End If
        Return Sketch
    End Function
    'Function For Axis selection
    Function SelectAxis() As DatumAxis
        Dim message As String = "Axis selection (x and y)"
        Dim title As String = "Axis selection"
            .Type = UFConstants.UF_datum_axis_type
            .Subtype = 0
        End With
        Dim Axis As DatumAxis = CType(selectedObject, DatumAxis)
        If Axis Is Nothing Then
            Return Nothing
        End If
        Return Axis
    End Function
        End If
        'Calling the sketch Function, sketch selection, addinf points in the list
            End If
        Next
        'Axis Selection
        Dim Axis1 As DatumAxis = SelectAxis()
        Dim Axis2 As DatumAxis = SelectAxis()
        'For loop for creating of AS
        Dim i As Integer
        For i = 0 To sketchpoints.count.tostring - 1
            Dim point1 As NXOpen.Point = CType(sketchpoints(i), NXOpen.Point)
            Dim datumAxis1 As NXOpen.DatumAxis = CType(Axis1, NXOpen.DatumAxis)
            Dim datumAxis2 As NXOpen.DatumAxis = CType(Axis2, NXOpen.DatumAxis)
        Next
        Messagebox.show("Done...")
    End Sub
End Module
Honored Contributor
Honored Contributor
The For loop was simplified. Also, a custom message was added to the SelectAxis function.
You might want to add a check to see if there is a sketch available in the part before prompting the user to select one. Also, if the selected sketch does not contain any points, a message to the user would help them understand why the journal didn't do anything.
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
            .Subtype = 0
        End With
            Return Nothing
        End If
        Return Sketch
    End Function
    Function SelectAxis(byval selectionMessage as string) As DatumAxis
        'Dim message As String = "Axis selection (x and y)"
            .Subtype = 0
        End With
        ui.SelectionManager.SelectObject(selectionMessage, title, scope, selectionAction, includeFeatures, keepHighlighted, selectionMask_array, selectedObject, cursor)
            Return Nothing
        End If
        Return Axis
    End Function
        markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Datum CSYS on sketch points")
            End If
        Next
        'Axis Selection
        Dim Axis1 As DatumAxis = SelectAxis("Select X direction")
        Dim Axis2 As DatumAxis = SelectAxis("Select Y direction")
        For each tempPoint as Point in sketchPoints
            xform2 = workPart.Xforms.CreateXform(tempPoint, direction1, direction2, NXOpen.SmartObject.UpdateOption.WithinModeling, 1.0)
        Next
    End Sub
End Module
I want also this part, where i say whic axis but didnt know how, so thx
I can add those checks.
I didnt undrstand this with loop Smiley Sad
U put temp point in this line only.
And yah ur code look more smaller. Smiley Happy
Thx a lot for ur time. Smiley Happy
