Get selection rule from blockstyler face selection
How do we get the selection intent rules that were used for selection through a blockstyler face selection block?
Suresh
Re: Get selection rule from blockstyler face selection
For example when I create a GroupFace feature using Region Faces option interactively any new faces within that region are automatically added to the feature.  But I cannot figure out how to get this information from the block styler face selection block and pass it to the GroupFaceBuilder.
I can get the selected faces and use FaceDumbRule as the SelectionIntentRule but this does not capture the selection intent rule.
Suresh
Did you try this?
Attila Szepesi, Application Engineer, graphIT Ltd.
Production: NX11.0.2 | TcUA 11.2 MP2 Patch 1 (11.2.2.1)
Development: VB.NET Testing: NX12.0
Thanks for the suggestion.  I have no problem selecting the faces with the intended selection rule.  My problem how to get that selection intent rules after the faces have been selected to use them in FeatureBuilder so that the feature remembers those selection intents.
Suresh
This is currently not possible. Face collector block only returns list of selected faces, it does not return NXOpen::Collector which contains this information.
You can log Enhancement request with GTAC.
SE-Advanced
Siemens Industry Software
