Get the associated solid or component by selecting view in DWG file in NX
How will I get the  associated solid or component by selecting view in DWG file in NX using VB.net ?
The attachment provided highlights the selected view and its part /assembly .
Your help is appreciated!
Juhi
Re: Get the associated solid or component by selecting view in DWG file in NX
Honored Contributor
Honored Contributor
The view that you have circled is actually associated with the "toycar_body" drafting component and NOT the "toycar_assembly" that you have highlighted.
How will I get part or assembly from view in a drawing sheet in vb.net ?
I've provided the snapshots in attachments to show what is required exactly. Your help will be appreciated!
Juhi
Hello Team,
Is there any update on last reply. We want to get component or solid associated with view basically component/solid is used to create the view using vb.net.
Please update us as soon as possible
Rupali
