Get the state/layer from a Geom object
(NXOpen JAVA)
I have a part that contains several layers, like you can see in the pictures below:
My question is this:
How can I get the matching state (2017-04-19 14_47_32-Jasc Paint Shop Pro - states_02.png) of each Geom ( 2017-04-19 14_46_28-NX 11 - Manufacturing - [test_dir.prt (Modified) ].png)?
(Assumming that in the original file only one state is presented and I already got all the Geom objects).
Tom.
Re: Get the state/layer from a Geom object
Objects that inherit from the DisplayableObject class have a .Layer property that you can query to see what layer the object resides on. Once you know the layer, you can use the layer manager's .GetState method to find the layer state (work layer, selectable, visible, or hidden).
If the "Geom" is not a displayable object (or even if it is), note you might have multiple solids selected (one for blank, one for part, possibly others) that may EACH be on separate layers.
So you may have to ask the "geometry" group parent for the various solids that are its "children" & find the layer(s) of those solids.
Thank you for your help.
I got the Geom
			nxopen.cam.FeatureGeometry featureGeometry1 = ((nxopen.cam.FeatureGeometry)m_WorkPart.camsetup().camgroupCollection().findObject("YOLO_1"));
			nxopen.cam.MillGeomBuilder millGeomBuilder1;
			millGeomBuilder1 = m_WorkPart.camsetup().camgroupCollection().createMillGeomBuilder(featureGeometry1);
 But I don't understand how to continue from here.
Tom.
Is it even possible?
Have you already checked out if "Save Layer and Layout" would be sufficient?
Sure you have to hit "save layer and layout" once when you have finished editing the geometry, but afterwards things should be no problem.
My main issue is to get the layer number from the 2017-04-19 14_46_28-NX 11 - Manufacturing - [test_dir.prt (Modified) ].png.
If you just need this to switch the layer settings, this is already available using "Save Layer and Layout" from within the geometry object and "Switch Layer and Layout" from the context menu of the geometry object.
If you need this for something different, then you need the following steps:
  1. cycle through the geometry group objects
  2. get each body of the specified part geometry
  3. check which layers contain the bodies
What is the goal you are trying to realize?
If we know what task you are trying to automate, we can better help you with the many ways that are available.
My final goal is this:
For each 2017-04-19 14_46_28-NX 11 - Manufacturing - [test_dir.prt (Modified) ].png I need to display only the relevant layer and run the "find features" option.
(Then I do some calculations, I delete the features, and move to the next 2017-04-19 14_46_28-NX 11 - Manufacturing - [test_dir.prt (Modified) ].png)
EDIT:
Thanks for your reply I managed to reach from the Geom to the relevant layer:
			Geometry part = geom.partGeometry();
			GeometrySetList gList = part.geometryList();
			GeometrySet[] content = gList.getContents();
			for(GeometrySet set : content)
				TaggedObject[] items = set.getItems();
				for(TaggedObject item : items)
					Body body = (Body) item;
					System.out.println(body.layer());
another little question: Is there an efficient way to get the name of the Geom parent of an operation?
Thanks again,
Tom.
I didn't test it, but I would guess:
Dim GeomGroup as NCGroup = myOp.GetParent(CAMSetup.View.Geometry)
Dim GroupName as String = GeomGroup.Name
Mark Rief
Retired Siemens
