Get tool from operation
(NX CAM)
How can I get the relevant tool from an opeartion?
Tom.
Re: Get tool from operation
Hello
Try this:
NXOpen.CAM.CAMObject camObject = (NXOpen.CAM.CAMObject)(NXObjectManager.Get(camObjectTag));
if (camObject is NXOpen.CAM.Operation)
                NXOpen.CAM.Operation op = (NXOpen.CAM.Operation)camObject;
                NXOpen.CAM.CAMObject tool = op.GetParent(NXOpen.CAM.CAMSetup.View.MachineTool);
Marek Pawlus, NCmatic
Production: NX 11.0.2
Development: C#, Tcl/Tk, CSE
Thank you!
And one more question - Is there a way to run on all the tools in the file (like I can run on the operations)?
Check out this OOTB sample:
(...)\UGOPEN\SampleNXOpenApplications\.NET\CAM\MCSSetFixtOffset1CycleAll.vb
So you can get an idea how to cycle objects in other ONT views...
'   DESCRIPTION
        ' Change the default value for fixture offset from 0 to 1.
		' This program will cycle through all MILL orient and TURN orient
		' geometry groups in the part, and if fixture offset is 0, set to 1.
		' This change was applied to all template parts in NX 8.5.
Here is anothere way to get the tool parent:
Dim ToolGroup as NCGroup = myOp.GetParent(CAMSetup.View.MachineTool)
Dim GroupName as String = ToolGroup.Name
Attached is a sample vb program that will cycle all tools in the tool view.
Mark Rief
Retired Siemens
