Get volume of a mesh - Use of CAE.SolidPropertyCheckBuilder
Siemens Pioneer Siemens Pioneer
Siemens Pioneer
Hi all,
I'm trying to get the volume of a mesh in a c# NXOpen dll on NX 10.
Interactively, it corresponds to click right on a Mesh, and then Solid Properties and there I can find the volume of the whole mesh.
I got advised to use CAE.SolidPropertyCheckBuilder but I didn't find how to use it properly.
Anyone has an idea on how to initialise it/use it ?
Thanks for your help !
Re: Get volume of a mesh - Use of CAE.SolidPropertyCheckBuilder
@Valene,
You need to instantiate a SolidPropertyCheckBuilder from the ModelCheckManager.
See the attached for an example of your application.
Siemens Pioneer
Sorry for the late reply.
The example helps a lot ! Thanks
Siemens Pioneer
Dear all,
It's been two years, but I'm still using this function.
I wanted to avoid to parse the output file and I found there's a function GetSolidPropertyValues which seems to correspond to what I want.
I tried to use it but the call to the function crashes without any nice error message.
Here's the code. Does someone has an idea ?
Thank you
SolidPropertyCheckBuilder* checkProp = theFemPart->ModelCheckMgr()->CreateSolidPropertyCheckBuilder();
checkProp->EvaluationTemparature()->SetRightHandSide("0");
checkProp->SetOutputOption(true);
vector<Mesh*> vecMesh;
vecMesh.push_back(mesh);
RelatedElemMethod* elemMethod = theFemPart->SmartSelectionMgr()->CreateRelatedElemMethod(vecMesh, false);
checkProp->Elements()->Selection()->Add(elemMethod);
checkProp->SetUserSpecifiedUnit(SolidPropertyCheckBuilder::UserUnitKgMilli);
checkProp->SetSplitMass(false);
checkProp->SetDisplayCgOption(false);
checkProp->SetDefaultTemperatureOption(true);
checkProp->SetCoupledSolutionOption(SolidPropertyCheckBuilder::CoupledSolutionOutputStructural);
NXObject* res = checkProp->Commit();
std::vector<NXOpen::CAE::SolidPropertyCheckBuilder::ValueRequest> valueTypes;
valueTypes.push_back(NXOpen::CAE::SolidPropertyCheckBuilder::ValueRequestVolume);
std::vector<NXOpen::Unit *> valueUnits;
std::vector<double> values;
checkProp->GetSolidPropertyValues(valueTypes, valueUnits, values);
checkProp->Destroy();
