Getting Border info of a drafting view
Hello All,
Is there any posibility to get border info(ex: height and width) of a drafting view?
In information window it shows only center location of the border.
Please help.
Abhi
8 REPLIES 8
Re: Getting Border info of a drafting view
When you say Height and Width of border, do you perhaps mean the Height and Width of the drawing sheet? What is the interactive command you are using that gives the center location of a drawing border?
My company still uses patterns for our borders so perhaps the new border tool has additional features (such as size) which I'm not familiar with. There are sample .NET programs in UGAnswer for obtaining the drawing sheet size if that is indeed what you are after.
Geoff Donohoo
NX10.0.3.5 & TC 10.1.4.2
Dell T3600 32Gb Ram, Nvidia Quadro 4000
Windows 7
nt UF_DRAW_ask_view_borders
const tag_t view_tag,
double view_borders [ 4 ]
Hope this Helps
Balakrishnan M
Hi @G_Donohoo
Thanks for your reply.
But you got me wrong. I place a base view of the model which exists in modelling.
When you place a base view or projected view in drafting sheet it shows a border. I want height and width of that border.
I have attached a image to give you more clarity.
In that image you see a borer of the view in yellow color.
Thank you.
int UF_DRAW_ask_view_borders(const tag_t view_tag,double view_borders [ 4 ])
This view_borders [ 4 ] gives xmin, ymin, xmax and ymax
Width = xmax -xmin
Height = ymax -ymin
Thanks & Regards
Balakrishnan M
Hi @BalakrishnanM
Thank you very much.This is exactly what I wanted.
Abhi
@BalakrishnanM
How can i do this in c#?
For UF_DRAW_ask_view_borders there is a need to add reference of uf_draw.h.
Is there any corresponding reference file for c#?
Thank you
Please start with NXOPEN. UF
create a UFSession object and use it.
@Abhi_Learner
Ya it worked. Thanx a lot
