Getting attributes from a feature
Hello everyone! I need help with the C# NX Open.
I can't get attributes from a feature. I tried the following piece of code, but it keep returning zero-length arrays.
Feature.AttributeInformation[] fAtts = theFeature.GetUserAttributes();
Any help is appreciated!
Re: Getting attributes from a feature
Seems to work for me. Are you sure the attribute has been applied to the feature itself as opposed to a body or face resulting from the feature?
I am pretty sure that I assigned attribute to a feature. There is something Lovecraftian to this story, because today it works. Smiley Very Happy
