Getting error no object found with this name
Hi All,
Below is the code where I'm looping thru all FCFs. But getting error at last line-
        For Each myFCF In workPart.Annotations.fcfs.ToArray()
             Dim x as string
             x = myFCF.JournalIdentifier
            MsgBox (Chr(34) & x & Chr(34))
        Dim markId1 As NXOpen.Session.UndoMarkId = Nothing
        markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Start")
        Dim fcf1 As NXOpen.Annotations.Fcf = CType(workPart.FindObject(Chr(34) & x & Chr(34)), NXOpen.Annotations.Fcf)
Any help will be appreciated.
Samadhan
NX Help Links: NX1102 | NX1202 | NX1847
Please mark post as an "Accepted Solution", if it answers your question/is more helpful!
Betreff: Getting error no object found with this name
You won't find any object if you add double quotes to the search string.
Jan
Jan Böttcher
Thank you Jan for your reply that solved my problem.
Actually I was trying to replace value in x which is handle id with double quote as recorded journal showed double quotes.
-Samadhan
Samadhan
The journal uses a literal string, so the double quotes are mandatory.
If you use a variable, you don't need the double quotes.
