Getting the View Associated with an Annotation
I want to be able to report which view each annotation on a drawing is associated with (Section View A-A, Top, Left, etc). I can do this for linear dimensions by using LinearDimensionBuilder.FirstAssociativity.GetValue to get the View. How can I get the views for all (or at least more) annotation types?
UFSession.View.AskViewDependentStatus always seems to return "SH01@0" instead of the view I need.
Edit: I've not tried Annotation.GetAssociativity(1).ObjectView. I'll update this thread after I give that a shot.
-A
Re: Getting the View Associated with an Annotation
Annotation.GetAssociativity(1).ObjectView worked for most annotations. For those that were associated to other objects on the drawing, I had to get the view of the object it was associated to. For example, for stacked annotations, I had to get the associativity of the parent of the stack.
