Getting the detail of 'SOL103 resp. sim' "attached" to a Response Simulation?
To all,
Does anyone know how one can get the name of the 'SOL 103 response simulation' "attached" to a response simulation?
Production: NX.CAE 9.0.3.4, NX.CAE 10.0.2.6
Re: Getting the detail of 'SOL103 resp. sim' "attached" to a Response Simulation?
After some "random" reading I stumbled across the
Dim ReferencedSolution As SimSolution
which is part of Class CAE.ResponseSimulation.SolutionBuilder. The ReferenceSolution 'returns or sets the referenced solution which must be a SEMODES *103 solution with modal results solved'. This is what I am after!
Does anyone know or can advice how to use it? I am not trying to "build" a new resp. sim. Only want to know what is the ReferenceSolution of a given CAE.ResponseSimulation.Solution
Any suggestion?
You still need to instantiate a builder using the existing Response Sim Solution. You can then query the ReferencedSolution property of the builder. Finally, destroy the builder without committing it.
that's exactly what I did. Seems to work!
