Getting the parts into Team Center session
Below code, brings the parts which are stored in the list into session in native environment.
What should I change so as to make the same in Team Center environment?
  Dim a As Integer = 0
For Each partNames As String In partList
Try
fileOpen(dosyaYolu & partsFolder & "\" & partList(a) & ".prt")
Catch ex As Exception
End Try
a = a + 1
Next
Re: Getting the parts into Team Center session
@metin_mehel
That is based on what you wrote inside "fileopen" method. if you want to open a teamcenter part using NXopen classes then, best approach is to record a journal or If you want to open the part using ufunc wrapper methods then, the best approach is to find the encoded filename. make sure you are passing correct revision in this case.
Post your fileopen method here and also let us know which option do you prefer.
伊尔凡
Replace the native path with the Teamcenter short-hand:
@DB/{Item ID}/{Item Revision}
So something like:
@DB/0815/A
Hope this helps.
