Help: Extracting curvatures from GeometricAnalysis::CurveCurvatureAnalysis
I can display a curve analysis using GeometricAnalysis::CurveCurvatureAnalysis. I would like to extract the curvature values at sampled points. What is the API for that. Also I can show the inflection points on the curve. But how to get the coordinates of those points thru program?
Re: Help: Extracting curvatures from GeometricAnalysis::CurveCurvatureAnalysis
For curvature, the easiest is the SNAP function
myCurve.Curvature
Other options are:
NXOpen.UF.UFModl.AskCurveProps
NXOpen.UF.UFEval.Evaluate
The first of these gives you curvature directly; the second one gives you derivatives, from which you can calculate curvature.
For inflexions:
NXOpen.UF.UFCurve.AskCurveInflections
山田
yamada
Thanks for the reply. I am looking for a way to directly extract data from Analysis. To use the functions you mentioned, I need to sample the cruve when I change my curve.
So, No one has better way to extract the curvature in an associative way?
