cancel
Help Palettes
Hi All,
How to create or setup help palett on resource bar. (See attached picture, I am using NX 8.5).
Thanking you
Nij
Re: Help Palettes
You can add new palettes in Menu > Preferences > Palettes.
Is this what you are looking for?
Mark Rief
Retired Siemens
Re: Help Palettes
HI Mark,
No, I want Help tab in resource bar, So that I can pop up contect sensitive help there when user presess F1 keyboard key
Thanking you
Nij
Re: Help Palettes
Nij wrote:
HI Mark,
Thanking you
Nij
I don't know if this is possible, but for sure it is not recommended.
We moved the help out fo the resource bar to a separate browser in NX5 for a lot of very good reasons. The layout does not fit well in a narrow pane, and a lot of excess resources were consumed by NX.
Mark Rief
Retired Siemens
Re: Help Palettes
HI Mark,
Yes this is possible, I am having this tab when I open NX in my machine, but in other machine NX, it is not found. I am missing some setup or configuration. I am unable to figure it how I did for my machine.
Thanking you
Nij
Re: Help Palettes
Maybe you can use the  Internet Explorer tab from the Resource Bar...
Re: Help Palettes
You need to set the variable UGII_DISABLE_HELP_PAGE to 0.
Either edit the file ...\UGII\ugii_env.dat and add a line to it:
UGII_DISABLE_HELP_PAGE=0
or
Windows Control Panel -> System -> Advanced System Settings (Upper left) -> Environment Variables
and create a user variable called UGII_DISABLE_HELP_PAGE and set the value to 0
tested and this works up until and NX8.5 & NX9. It doesn't work in NX10.
Anthony Galante - Senior Support Engineer - PhoenxPLM (Australia & New Zealand Siemens Solutions Partner)
http://www.phoenxplm.com.au/email/2014_signature/signature_videoCenter.jpg
Re: Help Palettes
Thank you Antony, its working after setting environment variable
Thanking you
Nij
