Hide/Show journal
' NX 5.0.1.4
' Journal created by cohon on Wed Aug 01 21:31:27 2007 Central Daylight Time
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
'   Menu: Fit
workPart.ModelingViews.WorkView.Fit()
'   Menu: Edit->Show and Hide->Show and Hide...
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Start")
theSession.SetUndoMarkName(markId1, "Show and Hide")
theSession.SetUndoMarkVisibility(markId1, Nothing, Session.MarkVisibility.Invisible)
Dim markId2 As Session.UndoMarkId
markId2 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Hide Sketches")
Dim numberHidden1 As Integer
numberHidden1 = theSession.DisplayManager.HideByType(DisplayManager.ShowHideType.Sketches, DisplayManager.ShowHideScope.AnyInAssembly)
Dim markId3 As Session.UndoMarkId
markId3 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Hide Curves")
Dim numberHidden2 As Integer
numberHidden2 = theSession.DisplayManager.HideByType(DisplayManager.ShowHideType.Curves, DisplayManager.ShowHideScope.AnyInAssembly)
Dim markId4 As Session.UndoMarkId
markId4 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Hide Datums")
Dim numberHidden3 As Integer
numberHidden3 = theSession.DisplayManager.HideByType(DisplayManager.ShowHideType.Datums, DisplayManager.ShowHideScope.AnyInAssembly)
'   Menu: Fit
'   Menu: Tools->Journal->Stop
End Sub
End Module
I've been using this journal for many years now. Is there a way to edit it so it doesn't "Hide" specific entities so long are Named?
Example, I name saved CSYS and/or Datum CSYS for my machining coordinate systems. I do not machine in NX, but my CAM system brings in NX CSYS's and if they're named they are easier to pick out on the list. I also tend to make lines on the csys and label those X,Y,Z.
But when I run the Hide construction geometry journal it hides everything except sheets and solids.
Rob Newcomb, CAD/CNC/Simulation manager
Elmhirst Industries, Specializing in Prototype sheet metal stampings and assemblies
Production: NX 11.0.2.7 / Autoform r7 /WorkNC 2018 r2
Testing:NX12.0.1.
PC: Rave Cadbeast: Intel(R) i7-4790K CPU @ 4.GHz /32gb ram /NVIDIA Quadro P2000 on Win10 Pro
Re: Hide/Show journal
So if a saved csys or curve is named, you want it to be shown; is this correct? Are you working with an individual part file or is this an assembly (in other words, what file owns the csys objects and curves that you want to show, the display part? or perhaps you need to display every named csys and curve in every component?)
Also, what is your current version of NX?
When I Run the Hide construction geometry journal, I would like to Hide all of the displayed construction geometry with the exception of those that are named via user defined Name.
for example I right click on a saved WCS, go down to properties and under the General tab. Name the saved WCS Die Tip.
I then run the hide all construction geometry journal, it hides all my datums,curves , sketches and other CSYS with the exception of the one I named.
Testing:NX12.0.1.
The following code will unblank all of the named coordinate systems and curves in the current work part. I'm not sure this is quite what you want; any named objects in other component files will not show up. Also, this code will not change the layer visibility; if the layer of a named object is invisible, this code will not make it visible.
' NX 5.0.1.4
Option Strict Off
Imports System
Imports NXOpen
Module Module2
    Sub Main()
        '   Menu: Fit
        For Each temp As CoordinateSystem In workPart.CoordinateSystems
            If temp.Name <> "" Then
                temp.Unblank()
                temp.RedisplayObject()
            End If
        Next
        For Each temp As Curve In workPart.Curves
                temp.Unblank()
            End If
        Next
        '   Menu: Fit
    End Sub
End Module
This version might work better, it should show all the named lines and coordinate systems even if they are an occurrence object (owned by a component but shown in the assembly).
' NX 5.0.1.4
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module2
    Sub Main()
        Dim theUfSession As UFSession = UFSession.GetUFSession
        '   Menu: Fit
        Dim objTag As Tag = Tag.Null
        Do
            theUfSession.Obj.CycleObjsInPart(theSession.Parts.Display.Tag, UFConstants.UF_line_type, objTag)
            If objTag = Tag.Null Then
                Exit Do
            End If
            Dim aLine As Line = Utilities.NXObjectManager.Get(objTag)
            If aLine.Name <> "" Then
                aLine.Unblank()
                aLine.RedisplayObject()
            End If
        Loop While True
        objTag = Tag.Null
        Do
            theUfSession.Obj.CycleObjsInPart(theSession.Parts.Display.Tag, UFConstants.UF_coordinate_system_type, objTag)
                Exit Do
            End If
            Dim aCsys As CoordinateSystem = Utilities.NXObjectManager.Get(objTag)
            If aCsys.Name <> "" Then
                aCsys.Unblank()
                aCsys.RedisplayObject()
            End If
        Loop While True
        '   Menu: Fit
    End Sub
End Module
Close,
If its already hidden and happens to have a name such as sketch curves I do not want them to become visible.
I'd also like Named Points to stay visible.
Thanks.
Testing:NX12.0.1.
Ok, try this one.
' NX 5.0.1.4
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Module Module2
    Sub Main()
        Dim namedAndUnblanked As New List(Of DisplayableObject)
        'find current coordinate systems, curves, and points that are named and not hidden
        Do
                Exit Do
            End If
            Dim theFeatureTag As Tag = Tag.Null
            theUfSession.Modl.AskObjectFeat(objtag, theFeatureTag)
            Dim theFeature As Features.Feature = Nothing
            If theFeatureTag = Tag.Null Then
                'unassociative line
                'continue processing
            Else
                theFeature = Utilities.NXObjectManager.Get(theFeatureTag)
                If TypeOf (theFeature) Is Features.SketchFeature Then
                    'skip sketch curves
                    Continue Do
                Else
                    'continue processing this line
                End If
            End If
            If aLine.Name <> "" AndAlso (Not aLine.IsBlanked) Then
                namedAndUnblanked.Add(aLine)
            End If
        Loop While True
        objTag = Tag.Null
        Do
                Exit Do
            End If
            If aCsys.Name <> "" AndAlso (Not aCsys.IsBlanked) Then
                namedAndUnblanked.Add(aCsys)
            End If
        Loop While True
        objTag = Tag.Null
        Do
            theUfSession.Obj.CycleObjsInPart(theSession.Parts.Display.Tag, UFConstants.UF_point_type, objTag)
                Exit Do
            End If
            Dim aPoint As Point = Utilities.NXObjectManager.Get(objTag)
            If aPoint.Name <> "" AndAlso (Not aPoint.IsBlanked) Then
                namedAndUnblanked.Add(aPoint)
            End If
        Loop While True
        '   Menu: Fit
        'redisplay named objects
        For Each temp As DisplayableObject In namedAndUnblanked
            temp.Unblank()
        Next
        '   Menu: Fit
    End Sub
End Module
Seems to work, I've been on the shop floor most of the day.
Thanks!
Testing:NX12.0.1.
