Hide existing buttons in NX
Is there a way (through .men files, nxopen dll or other) to hide buttons in the simulation objects button list in the SIM (see image).
I only need to show some of the available buttons, not all of them.
Thanks.
3 REPLIES 3
Re: Hide existing buttons in NX
Hi @EGhossein
Is this for your workstation environment? or to everyone.
You can't hide the NX default buttons through NXOpen or using menu files.
You can create a custom NX-Role (Create Custom Role) for your requirement and show / hide the buttons as required and apply it in the NX session. The same file can be shared among the other persons who indeed of the same environment.
Thank you.
Can you show me for instance how to remove the first button in the image ("Cyclic Symetry") in a new custom role.
Thanks.
Hi @EGhossein ,
You'll get some idea from this video:
Samadhan
GTAC | NX Help: NX1102 | NX1202 | NX1847
Please mark post as an "Accepted Solution", if it answers your question/is more helpful!
