Highlight modified components ?
Is there a way to check if a component is highlighted in the 3D viewer? I would like to return a boolean value if possible.
Re: Highlight modified components ?
Hi!
Perhaps you can use the SelectionManager
UI theUI = UI.GetUI();
int numberOfSelectedObjects = theUI.SelectionManager.GetNumSelectedObjects();
selectedObject = (NXOpen.Assemblies.Component)theUI.SelectionManager.GetSelectedTaggedObject(i);
to check if a component is selected (= highlighted).
