Hole in Extruded Polygon
Hello Guys,
Here is a code, First it creates polygon, extrude it and make hole in it.
SO Problem is that I am not able to shift it in X direction.(Ex X=50mm)
using System;
using NXOpen;
using NXOpen.Features;
public class NXJournal
public static void Main(string[] args)
NXOpen.Session theSession = NXOpen.Session.GetSession();
NXOpen.Part workPart = theSession.Parts.Work;
NXOpen.Part displayPart = theSession.Parts.Display;
// Menu: Insert->Sketch Curve->Polygon...
NXOpen.SketchPolygon nullNXOpen_SketchPolygon = null;
NXOpen.SketchPolygonBuilder sketchPolygonBuilder1;
sketchPolygonBuilder1 = workPart.Sketches.CreateSketchPolygonBuilder(nullNXOpen_SketchPolygon);
sketchPolygonBuilder1.RadiusDimension.RightHandSide = "70";
sketchPolygonBuilder1.LengthDimension.RightHandSide = "100";
sketchPolygonBuilder1.RotationDimension.RightHandSide = "90";
NXOpen.DatumAxis datumAxis1 = (NXOpen.DatumAxis)workPart.Datums.FindObject("DATUM_CSYS(0) Y axis");
Direction direction1;
direction1 = workPart.Directions.CreateDirection(datumAxis1, NXOpen.Sense.Forward, NXOpen.SmartObject.UpdateOption.WithinModeling);
NXOpen.DatumPlane datumPlane1 = (NXOpen.DatumPlane)workPart.Datums.FindObject("DATUM_CSYS(0) YZ plane");
NXOpen.Features.DatumCsys datumCsys1 = (NXOpen.Features.DatumCsys)workPart.Features.FindObject("DATUM_CSYS(0)");
Point3d origin1 = new Point3d(0, 0, 0);
Point point1;
point1 = workPart.Points.CreatePoint(origin1);
// NXOpen.Point point1 = (NXOpen.Point)datumCsys1.FindObject("POINT 1");
NXOpen.Xform xform1;
xform1 = workPart.Xforms.CreateXformByPlaneXDirPoint(datumPlane1, direction1, point1, NXOpen.SmartObject.UpdateOption.WithinModeling, 0.625, false, false);
NXOpen.CartesianCoordinateSystem cartesianCoordinateSystem1;
cartesianCoordinateSystem1 = workPart.CoordinateSystems.CreateCoordinateSystem(xform1, NXOpen.SmartObject.UpdateOption.WithinModeling);
NXOpen.Features.Feature nullNXOpen_Features_Feature = null;
NXOpen.Features.DatumCsysBuilder datumCsysBuilder1;
datumCsysBuilder1 = workPart.Features.CreateDatumCsysBuilder(nullNXOpen_Features_Feature);
datumCsysBuilder1.Csys = cartesianCoordinateSystem1;
datumCsysBuilder1.DisplayScaleFactor = 1.25;
NXOpen.Features.Feature feature1;
feature1 = datumCsysBuilder1.CommitFeature();
datumCsysBuilder1.Destroy();
NXOpen.Sketch nullNXOpen_Sketch = null;
NXOpen.SketchInPlaceBuilder sketchInPlaceBuilder1;
sketchInPlaceBuilder1 = workPart.Sketches.CreateSketchInPlaceBuilder2(nullNXOpen_Sketch);
sketchInPlaceBuilder1.Csystem = cartesianCoordinateSystem1;
sketchInPlaceBuilder1.PlaneOption = NXOpen.Sketch.PlaneOption.Inferred;
NXOpen.NXObject nXObject1;
nXObject1 = sketchInPlaceBuilder1.Commit();
sketchInPlaceBuilder1.Destroy();
NXOpen.Sketch sketch1 = (NXOpen.Sketch)nXObject1;
sketch1.Activate(NXOpen.Sketch.ViewReorient.False);
NXOpen.Features.DatumCsys datumCsys2 = (NXOpen.Features.DatumCsys)feature1;
// NXOpen.Point point2 = (NXOpen.Point)datumCsys2.FindObject("POINT 1");
Point3d origin2 = new Point3d(0.0, 0, 0);
Point point2;
point2 = workPart.Points.CreatePoint(origin2);
NXOpen.Xform nullNXOpen_Xform = null;
NXOpen.Point point3;
point3 = workPart.Points.CreatePoint(point2, nullNXOpen_Xform, NXOpen.SmartObject.UpdateOption.WithinModeling);
sketchPolygonBuilder1.CenterPoint = point3;
point3.RemoveParameters();
NXOpen.Point3d coordinates1 = new NXOpen.Point3d(0.0, 0.0, 0.0);
point3.SetCoordinates(coordinates1);
theSession.ActiveSketch.AddGeometry(point3, NXOpen.Sketch.InferConstraintsOption.InferNoConstraints);
NXOpen.NXObject nXObject2;
nXObject2 = sketchPolygonBuilder1.Commit();
theSession.ActiveSketch.Update();
sketchPolygonBuilder1.Destroy();
// Menu: File->Finish Sketch
NXOpen.Sketch sketch2;
sketch2 = theSession.ActiveSketch;
theSession.ActiveSketch.Deactivate(NXOpen.Sketch.ViewReorient.False, NXOpen.Sketch.UpdateLevel.Model);
// Menu: Insert->Design Feature->Extrude...
NXOpen.Features.ExtrudeBuilder extrudeBuilder1;
extrudeBuilder1 = workPart.Features.CreateExtrudeBuilder(nullNXOpen_Features_Feature);
extrudeBuilder1.Limits.StartExtend.Value.RightHandSide = "0";
extrudeBuilder1.Limits.EndExtend.Value.RightHandSide = "100";
NXOpen.Section section1;
section1 = workPart.Sections.CreateSection(0.0095, 0.01, 0.5);
extrudeBuilder1.Section = section1;
extrudeBuilder1.AllowSelfIntersectingSection(true);
NXOpen.Features.Feature[] features1 = new NXOpen.Features.Feature[1];
features1[0] = sketch2.Feature;
NXOpen.CurveFeatureRule curveFeatureRule1;
curveFeatureRule1 = workPart.ScRuleFactory.CreateRuleCurveFeature(features1);
section1.AllowSelfIntersection(true);
NXOpen.SelectionIntentRule[] rules1 = new NXOpen.SelectionIntentRule[1];
rules1[0] = curveFeatureRule1;
NXObject[] geoms = sketch2.GetAllGeometry();
NXObject nx=geoms[0];
NXOpen.NXObject nullNXOpen_NXObject = null;
NXOpen.Point3d helpPoint1 = new NXOpen.Point3d(0,0,0);
section1.AddToSection(rules1, nx, nullNXOpen_NXObject, nullNXOpen_NXObject, helpPoint1, NXOpen.Section.Mode.Create, false);
NXOpen.Direction direction2;
direction2 = workPart.Directions.CreateDirection(sketch2, NXOpen.Sense.Forward, NXOpen.SmartObject.UpdateOption.WithinModeling);
extrudeBuilder1.Direction = direction2;
extrudeBuilder1.ParentFeatureInternal = false;
NXOpen.Features.Feature feature2;
feature2 = extrudeBuilder1.CommitFeature();
extrudeBuilder1.Destroy();
NXOpen.Features.HolePackageBuilder holePackageBuilder1 = workPart.Features.CreateHolePackageBuilder(null);
holePackageBuilder1.Type = NXOpen.Features.HolePackageBuilder.Types.GeneralHole;
holePackageBuilder1.GeneralSimpleHoleDiameter.RightHandSide = "50";
holePackageBuilder1.HoleDepthLimitOption = NXOpen.Features.HolePackageBuilder.HoleDepthLimitOptions.ThroughBody;
holePackageBuilder1.Tolerance = 0.01;
holePackageBuilder1.HolePosition.DistanceTolerance = 0.01;
NXOpen.Body[] targetBodies3 = new NXOpen.Body[1];
NXOpen.Features.BodyFeature Cyl = (NXOpen.Features.BodyFeature)feature2;
// NXOpen.Features.Cylinder Cyl = (NXOpen.Features.Cylinder)cylinder1;
targetBodies3[0] = Cyl.GetBodies()[0];
holePackageBuilder1.BooleanOperation.SetTargetBodies(targetBodies3);
holePackageBuilder1.BooleanOperation.Type = NXOpen.GeometricUtilities.BooleanOperation.BooleanType.Subtract;
Point3d origin3 = new Point3d(100, 0, 0);
Point point21;
point21 = workPart.Points.CreatePoint(origin3);
NXOpen.Point[] points2 = new NXOpen.Point[1];
points2[0] = point21;
NXOpen.CurveDumbRule curveDumbRule1;
curveDumbRule1 = workPart.ScRuleFactory.CreateRuleCurveDumbFromPoints(points2);
holePackageBuilder1.HolePosition.AllowSelfIntersection(true);
NXOpen.SelectionIntentRule[] rules2 = new NXOpen.SelectionIntentRule[1];
rules2[0] = curveDumbRule1;
NXObject nullNXObject = null;
Point3d helpPoint2 = new Point3d(0.0, 0.0, 0.0);
holePackageBuilder1.HolePosition.AddToSection(rules2, nullNXObject, nullNXObject, nullNXObject, helpPoint2, NXOpen.Section.Mode.Create, false);
NXObject hole = holePackageBuilder1.Commit();
holePackageBuilder1.Destroy();
public static int GetUnloadOption(string dummy) { return (int)NXOpen.Session.LibraryUnloadOption.Immediately; }
Re: Hole in Extruded Polygon
@Krishna11
If I undertand, you want to change the X coordinate of you hole.
Close to the end of your code is this line: Point3d origin3 = new Point3d(100, 0, 0)
Haven't tested but it seems the coordinates of the point. Try to change 100 to 50
Hello Sir,
That point has been used in a code for locating hole point on the face of the cylinder.
The above problem, that is shifting of polygon, could it be possible by modifying/removing above some of find object method()?
