How To: start the ray traced studio programatically in NX12
Dear community,
I need to start the ray traced studio programatically (as oposed to a "manual-start"). Is there a way to reach this ? This is needed for an automatization process in withing the required application.
The starting of the ray traced studio is not supported by the standard journaling. However if the ray traced studio is already opend the save image (static image) is supported.....
I have tried to use the SendKey() command to try to simulate the "ctrl+shift+w" key combination (manual start) but this has not worked (maybe I need to learn more).
starting the ray traced studio "manually"
Any "progammatically-workaorund" is appreciated.
Many thanks
3 REPLIES 3
Re: How To: start the ray traced studio programatically in NX12
Have you tried Session.ApplicationSwitchImmediate Method?
Suresh
Technisites Australia
Production: NX10.0.3 Developing: NX11.0.2.7, NX12.0.2, NX1847,
Development: C++, C# .Net, VB .Net, Python, KF
Siemens Genius Siemens Genius
Siemens Genius
It's not an Application that you can change to.
We would like to change to the task environment to get the result by the Ray Trace Studio created. But as discribed with NXOpen
Many thanks to you all :-)
Unfortunatelly i could not find so far a solution programmatically
