How can I copy registed NX Shortcut keys in my PC to another PC?
Hi, Everybody!
I want to copy registed NX Shortcut keys in my PC to another PC?
How can I do?
Please let me know...
Thank you!
Re: How can I copy registed NX Shortcut keys in my PC to another PC?
Roles will do this
Thanks to your attention to my issue and your answer!
But, I have no idea to control role...
Could you explain about control role for me?
Thank you!
Best Regards!
Hi @LittleWillie76,
This is in context of the native NX.
In the 'Roles' navigator RMB > New User Role. In Role Properties dialog provide the name fo the role and note the file name with suffix '.mtx' that will contain your custom role settings.
You will get this file at location 'C:\Users\user_profile\AppData\Local\Siemens\NX100\roles'. Copy the file 'nx_role0.mtx' and paste it to other machine at same location mentioned above. If there is no custom role defined in NX of other machine then you need to create the 'roles' folder and paste the file at that location. Restart NX and apply the role (copied) that will appear in the Roles navigator.
Special thanks to your favor!
I'm so sorry, but I was bothered you...
I get to  knew for sure about NX role function by your help at this time.
Thank you!
LittleWillie76
