How can I get the text which I selected in the listbox?
I got a problem that I made a listbox and some data inside, but how can I get the data which I selected in the listbox? I use NX6.0.  VB .NET
Best Regards
Christian
Re: How can I get the text which I selected in the listbox?
Is this a wndows form listbox or a block styler list box?
For windows form listbox use listbox.selecteditem.
For block styler listbox.selecteditemindex or listbox.selecteditemstring.
Suresh
We have an example program in the Solution Center called
Sample NX Open .NET Visual Basic program : report block styler list box selected items
You can also find it if you search for the string "nx_api4097".
this is the essential bit from the update callback:
            If block Is list_box0 Then
                lw.WriteLine("Current SelectedItems are:")
                Dim pl As PropertyList = list_box0.GetProperties()
                Dim items() As String = pl.GetStrings("ListItems")
                Dim selected() As Integer = pl.GetIntegerVector("SelectedItems")
                For Each picked As Integer In selected
                    lw.WriteLine("  " & items(picked))
                Next
                ' This demonstrates limiting the number of selected items to 2
                If selected.Length > 2 Then
                    Dim twomax() As Integer = {selected(0), selected(1)}
                    pl.SetIntegerVector("SelectedItems", twomax)
                End If
                pl.Dispose()
            End If
Hi SteveLabout
Thank you very much! You give me a big help!
Best Regards
Christian
Hi Technisites
It was used in a block styler list box, listbox.selecteditemindex or listbox.selecteditemstring can not be used in NX6.0, but thanks anyway!
Best Regards
Christian
