How can I manage multi language on Nx drawing sheets
I looking for a solution to  manage multi language on/ with Nx drawing sheets.
For example one sheet in english, doing something switch it to german, french,....
Can someone give me advice?
uwenx
Re: How can I manage multi language on Nx drawing sheets
This is possible via Journal that delete the old title block and replace with the new in different language, but what about the inside information like description or material name ?
Describe your process.
Thank you...
Using NX 11 / RuleDesigner PDM
thank you Cuba
on response, seem to be no problem for anyone...
I haven't done it so far, there is a worklow to put the several localisated workflow on different
layers or sheets... but I have to switch them, no automation.
I'd like to have a workfow, to open a base drawing and and child drawings using linked  views and dimension from the base drawing with several localisated child sheets.
No way to do it this way in nx, yes an ER, but I have to solve the problem in near future, and it would be nice to have a best practice on this issue.
uwenx
