Do you mean
Reply
How can I model/create a conical edge blend using Boundary Radius and Center Radius values?
I have looked at using UF_MODL_create_edge_blend_mult  for multiple radius points,  but I cannot see how/where to simply use the 2 parameters (Boundary Radius & Center Radius) that are available in the Edge Blend dialog box, when running NX in modelling mode?
I have successfully used the simple blend function UF_MODL_create_blend
However, I am not familiar with using UF_MODL_create_edge_blend_mult  and it seems to be key to the solution.
Am I looking in the wrong area? Any help would be appreciated!
Thank You
