How can I programmatically edit an asserted mass property value?
It would be really nice if asserted values could be tied to an expression, so they could be calculated, rather than hard-coded  (maybe in a future release?).  Since that doesn't appear to be the case, I am trying to make a tool to update the asserted values programmatically.  Is it possible to unlock the MassPropWeight attribute, or update it through the NXOpen API?
