How can you get the bounding box of a component in an assembly?
I need to get the bounding box of a component in an assembly.
Normally, I would use  UF_MODL_ask_bounding_box_exact  but won't work if I pass in a component.   I can get the Bodies from the components but this gives me their orginal location and not the location in the assembly context.
UF_MODL_ask_bounding_box_exact  seems to indicate I can get what I want if I have the right occurrence but I'm also not sure how tho get the right occurences.
The documentation isn't really clear. Can anyone point me in the right direction?
4 REPLIES 4
Re: How can you get the bounding box of a component in an assembly?
If you have a reference to the component and the prototype body, you can get the occurrence body with the .FindOccurrence method.
myOccBod = {component ref}.FindOccurrence({proto body})
(min_corner, directions, distances) = self.theUfSession.ModlGeneral.AskBoundingBoxExact(cubeid.Tag,0)
I used that for bounding boxes but I don't know if it will give you the original origin in an assembly
Hi Alex,
Yeah, that is esentially the same funciton I'm using in C++  just in python space.
That was the answer! It seems so obvious now. Thanks @cowski1
